9 years agoMega Wizard dual Clock FIFO Strange behavior !!!!!
Hullo guys , I have a Cyclone ||| board and im working on an application that uses dual clock 16-bit , 16-word deep FIFO . The write signal and clock r from the FPGA itself, and the read signal and ...
9 years agoNot really a lot of detail - are you sure write enable is low? are write enable and read enable are synchronised with the correct clocks? Are you sure the read enable is even asserted?
