11 years agoMega Function RAM I/O Data Bus
I'm trying to implement a memory buffer between microcontroller and EP3C16 . I'm using Mega function to generate the RAM memory. The problem is that it generates separate input and output data bus. I...
11 years agoThe FPGA's internal RAM can only be generated with separate input and output buses. You can't generate one with a bi-directional data bus.
You'll have to wrap your RAM with some logic that determines when to: a) read the RAM's output bus and drive it to the Micro and b) when to tri-state the FPGA's pins and drive the data received from the Micro into the RAM via the input bus. Cheers, Alex
