11 years agoMeasuring processing time
Hi. Imagine I have the following schematic in Quartus II http://www.alteraforum.com/forum/attachment.php?attachmentid=11037&stc=1 How can I measure the time elapsed from the instant the clock s...
11 years agoIf the data will arrive several clocks later, you will need some sideband "valid" signal generated from the LCG module, which you can connect to the wren port on the ram, or keep as a sideband signal around the ram.
This is not a problem of timing. THis is a problem of the design.
