14 years agomeaning of transport delay
I wonder anybody can explain me the meaning of transport delay and how differ from just (after) statement. thanks Pete
14 years agoHere is wiki statement on delta delay and similar statements seen in many other resources:
--- Quote Start --- In vhdl (http://en.wikipedia.org/wiki/vhdl) simulations, all signal assignments occur with some infinitesimal delay, known as delta delay. Technically, delta delay is of no measurable unit, but from a hardware design perspective one should think of delta delay as being the smallest time unit one could measure, such as a femtosecond(fs). --- Quote End --- this is an example of how it can cause problems: a <= b; -- comb. statement one may think that in functional simulation it means (a) is wired to (b) and hence if (b) changes from 0 to 1 so would (a) with zero delay(concurrent). but try it and use a clock to sample both (a) & (b),keep changing clock phase and you will get at some point a strange result. clock samples (a) as 0 but (b) as 1 The solution is to generate all signals from a reference signal e.g. clock...etc. if we make (b) the reference then: b1 <= b; a <= b; thus (b1) & (a) will have no delta delay.
