14 years agomeaning of transport delay
I wonder anybody can explain me the meaning of transport delay and how differ from just (after) statement. thanks Pete
14 years ago --- Quote Start --- Delta delay is not a 'simulation bug' is in no way dependant on 'simulator resolution' and is not 'too small to be visible' (open a list window and see for yourself). --- Quote End --- No certainly it is not a bug per se but I amplified the expression to convey that it got nothing to do with design. I know for sure it depends on update rate and hence I thought it will depend on resolution(step). As to visibility, I mean on the waveforms... are we talking about same thing? Good to see your comments here as it stimulates further research. --- Quote Start --- the 'after' keyword does not imply inertial delay. Rather it is the lack of the word 'transport' that implies inertial delay. --- Quote End --- Just different wording of same concept. Naturally I mean by after as after on its own. --- Quote Start --- Actually it would be 'wait until rising_edge(clk)'...but regardless, waiting on a signal is not an assignment statement therefore it is not an 'inertial' or a 'transport' delay. --- Quote End --- again I am referring to clk edge, not actual syntax and I say "in effect" which means it is my personal perspective and certainly not that of simulator designers who will have their own intricate terminology. --- Quote Start --- There is no continuous sampling going on. A 'transport' delay simply means that a previously scheduled transition on a signal will not be erased from the signal's queue of scheduled transitions when a new assignment comes along. --- Quote End --- Just different wording of same thing...the simulator tool is sampling(or not erasing) at start of every of its cycles, I don't mean sampling in the sense of a clk edge or ADC. Thanks for the comments.
