meaning of instructions
i'm a beginner in vhdl,so i have a program that i want to understand some instrunctions and functionalities.My program is:
PROCESS(clk, reset)
BEGIN
IF reset = '1' THEN
ready <= '1';
state <= TS2D_READY;
ELSE
IF clk'event AND clk = '1' THEN
CASE state IS
WHEN TS2D_READY =>
CASE ctrl_sig IS
WHEN Dwt2dCtrlVector(TCTRL_DWT2D_WIDTH) =>
width <= UNSIGNED(ctrl_data);
WHEN Dwt2dCtrlVector(TCTRL_DWT2D_HEIGHT) =>
height <= UNSIGNED(ctrl_data);
WHEN Dwt2dCtrlVector(TCTRL_DWT2D_TMP_DATA_OFFSET) =>
tmpDataOffset <= UNSIGNED(ctrl_data);
WHEN Dwt2dCtrlVector(TCTRL_DWT2D_LEVELS) =>
levels <= TO_INTEGER(UNSIGNED(ctrl_data));
state <= TS2D_INIT_HORIZ;
ready <= '0';
WHEN OTHERS =>
END CASE;
WHEN TS2D_INIT_HORIZ =>
src_cur <= (others => '0');
dst_cur <= (others => '0');
counter <= 0;
state <= TS2D_START_HORIZ;
WHEN TS2D_START_HORIZ =>
CASE counter IS
WHEN 0 =>
dwt_ctrl_sig <= DwtCtrlVector(TCTRL_SRC_START_OFFSET);
dwt_ctrl_data <= STD_LOGIC_VECTOR(RESIZE(src_cur * CST_BUF_WIDTH, CST_CTRL_DATA_BUS_WIDTH));
WHEN 1 =>
dwt_ctrl_sig <= DwtCtrlVector(TCTRL_SRC_STEP);
dwt_ctrl_data <= STD_LOGIC_VECTOR(TO_UNSIGNED(1, CST_CTRL_DATA_BUS_WIDTH));
WHEN 2 =>
dwt_ctrl_sig <= DwtCtrlVector(TCTRL_DST_START_OFFSET_LO);
dwt_ctrl_data <= STD_LOGIC_VECTOR(RESIZE(dst_cur * CST_BUF_WIDTH + tmpDataOffset, CST_CTRL_DATA_BUS_WIDTH));
WHEN 3 =>
dwt_ctrl_sig <= DwtCtrlVector(TCTRL_DST_START_OFFSET_HI);
dwt_ctrl_data <= STD_LOGIC_VECTOR(RESIZE(dst_cur * CST_BUF_WIDTH + SHIFT_RIGHT(width, 1) + tmpDataOffset, CST_CTRL_DATA_BUS_WIDTH));
WHEN 4 =>
dwt_ctrl_sig <= DwtCtrlVector(TCTRL_DST_STEP_LO);
WHEN 5 =>
dwt_ctrl_sig <= DwtCtrlVector(TCTRL_DST_STEP_HI);
WHEN 6 =>
dwt_ctrl_sig <= DwtCtrlVector(TCTRL_ELEM_COUNT);
dwt_ctrl_data <= STD_LOGIC_VECTOR(width);
WHEN 7 =>
dwt_ctrl_sig <= DwtCtrlVector(TCTRL_IGNORE);
state <= TS2D_CONTINUE_HORIZ;
WHEN OTHERS =>
END CASE;
counter <= counter + 1;
WHEN TS2D_CONTINUE_HORIZ =>
IF dwt_ready = '1' THEN
IF src_cur = height - 1 THEN
state <= TS2D_INIT_VERT;
----------- when testing horizontal pass only
-- state <= TS2D_TERMINATE;
ELSE
src_cur <= src_cur + 1;
dst_cur <= dst_cur + 1;
counter <= 0;
-- restart dwt
END IF;
END IF;
WHEN TS2D_INIT_VERT =>
counter <= 0;
state <= TS2D_START_VERT;
WHEN TS2D_START_VERT =>
CASE counter IS
WHEN 0 =>
dwt_ctrl_data <= STD_LOGIC_VECTOR(RESIZE(src_cur + tmpDataOffset, CST_CTRL_DATA_BUS_WIDTH));
WHEN 1 =>
dwt_ctrl_data <= STD_LOGIC_VECTOR(TO_UNSIGNED(CST_BUF_WIDTH, CST_CTRL_DATA_BUS_WIDTH));
WHEN 2 =>
dwt_ctrl_data <= STD_LOGIC_VECTOR(RESIZE(dst_cur, CST_CTRL_DATA_BUS_WIDTH));
WHEN 3 =>
dwt_ctrl_data <= STD_LOGIC_VECTOR(RESIZE((dst_cur + SHIFT_RIGHT(height, 1) * CST_BUF_WIDTH), CST_CTRL_DATA_BUS_WIDTH));
WHEN 4 =>
WHEN 5 =>
WHEN 6 =>
dwt_ctrl_data <= STD_LOGIC_VECTOR(height);
WHEN 7 =>
state <= TS2D_CONTINUE_VERT;
WHEN OTHERS =>
END CASE;
WHEN TS2D_CONTINUE_VERT =>
IF src_cur = width - 1 THEN
state <= TS2D_NEXT_LEVEL;
ELSE
counter <= 0;
-- restart dwt
END IF;
END IF;
WHEN TS2D_NEXT_LEVEL =>
IF levels = 1 THEN
ELSE
width <= SHIFT_RIGHT(width, 1);
height <= SHIFT_RIGHT(height, 1);
levels <= levels - 1;
END IF;
WHEN TS2D_TERMINATE =>
ready <= '1';
END CASE;
END IF;
END IF;
END PROCESS;
-------->i want to know the meaning of instructions in gras.
Please help me
1 Reply
All of those are type conversions. It is really just a VHDL thing - it has no effect on the underlying hardware.
THe (others => '0') is just setting all bits in the bus to '0'
