16 years agoMay DCLK toggle in user mode after PS configuration?
So far I only used AS-mode and JTAG for FPGA configuration. For a new C4 design I want to use PS-mode. Because I only have one clock source on my microcontroller, I want to use this clock-sig...
16 years ago --- Quote Start --- I did the exact same thing on an Arria GX and it works great. I routed DCLK to another pin and once the PS config is done, I use the other pin as a clock for a part of my system. Before I did this, I did a lot of digging and found in one of the Arria documents that DCLK can toggle after the config is done. I forgot which document that was. --- Quote End --- Hi Moose of Iron, Good to hear that you got this working. That gives me confidence. I will also test it and post the results. That may take some time, because of lack of hardware at this moment. Regards, Ton
