15 years agoMaxPlus 2: compiling errors
Hello everyone, i am berni69 and I'm studing telematics with our software, but like all the begginers in a new field, i have some mistake's programming in vhdl. For this reason the compiler show me e...
15 years agoThe error message isn't fully correct, because there is no else clause to the clock edge condition. Quartus gives a better understandable message.
--- Quote Start --- Error (10818): Can't infer register for "n[0]" at mod_tr.vhd(22) because it does not hold its value outside the clock edge --- Quote End --- The code can be compiled, when you change it like this:process (start,clk,clr)--contador
variable n: integer range 0 to 4;for the
begin
if clk'event and clk='1'then
n:=contador;
if start='1' or clr='1' then
n:=0;
elsif contador/=4 then
n:=n+1;
elsif contador=4 then
clr<='1';
end if;
contador <= n;
end if;
end process; You can write the same logic without the variable n. I don't think, that the code works as expected, because the signal clr is only set but never reset.
