10 years agoMaximum Size of Flash Memory Supported by CycloneIII
Dear Host,
Please tell me, how much maximum density of Flash Memory is supported by Cyclone III EP3C120F780I?15 Replies
Please tell me one more point that i have used Cyclone III DSP Development Kit. On this kit, (32Mx16) Flash Memory is used. Part Number is S29GL512N. In this flash, nbyte signal is used for the 8-bit and 16-bit selection. The flash is successfully programmed.
Now, i have design FPGA card and use 1Gb Flash Memory having part number S29GL01GS. Its size is 128MB. In this memory, nbyte signal is not present. I have write my software that was used with previous memory. How can i accommodate the nbyte pin in Flash controller. If i run the Test program on it, the program is failed. Please provide the remedy for this issue. I am very worried about this fault. Regards, Mohsin Hayat - Altera_Forum
Ah Sir, through our conversation, i got your point. I am using it for General Purpose in my design.I am not bound for size. There are limitations in Flash Controller. Am i right?
Sorry. I though you meant to connect to a flash memory for general purpose use in your design.
If you indeed want to configure fpga from a parallel flash, what you find in the datasheet is true: you are bound to the listed devices families. You could also exceed those flash sizes, but you must drive the extra address pins - Altera_Forum
The maximum size doesn't depend on the FPGA model itself, but on the flash controller you implement inside.
