10 years agoMaximum Size of Flash Memory Supported by CycloneIII
Dear Host, Please tell me, how much maximum density of Flash Memory is supported by Cyclone III EP3C120F780I?
10 years agoSorry. I though you meant to connect to a flash memory for general purpose use in your design.
If you indeed want to configure fpga from a parallel flash, what you find in the datasheet is true: you are bound to the listed devices families. You could also exceed those flash sizes, but you must drive the extra address pins
