10 years agoMaximum Size of Flash Memory Supported by CycloneIII
Dear Host, Please tell me, how much maximum density of Flash Memory is supported by Cyclone III EP3C120F780I?
10 years agoPlease tell me one more point that i have used Cyclone III DSP Development Kit. On this kit, (32Mx16) Flash Memory is used. Part Number is S29GL512N. In this flash, nbyte signal is used for the 8-bit and 16-bit selection. The flash is successfully programmed.
Now, i have design FPGA card and use 1Gb Flash Memory having part number S29GL01GS. Its size is 128MB. In this memory, nbyte signal is not present. I have write my software that was used with previous memory. How can i accommodate the nbyte pin in Flash controller. If i run the Test program on it, the program is failed. Please provide the remedy for this issue. I am very worried about this fault. Regards, Mohsin Hayat
