MAX3000A Ambient Temperature Range
The EPLD-TQFP44 MAX3064A 10N or similar returns in the last available data sheet (June 2006, ver. 3.5) a maximum ambient operating temperature of 70 ° for commercial items and 85 ° for the industrial ones. However the Altera site (https://www.altera.com/products/general/devices/dev-format.html) says that the commercial components have a Ta range from 0° to 85°. The same informations also appears in the Buy section (http://www.buyaltera.com/scripts/partsearch.dll/multisearch?site=altera&lang=en&keywords=epm3064) and seems relative to the component RoHS compliant.
So, if I buy a RoHS compliant chip, what is the commercial ambient temperature range? Are correct the information on data sheet or on Altera site?2 Replies
See table 13 on page 23 of the max 3000a programmable logic device family data sheet (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ds/m3000a.pdf).
I'm suspicious of the reference to 0-85 via buyaltera. If you select any of the RoHS compliant commercial parts (...C..-..N) they also have a link to the above datasheet which states 0-70. I (too) suggest you seek clarification from Altera. Cheers, Alex - Altera_Forum
Normally I wold refer to the info in the datasheet. To confirm, I think you should contact your FAE to clarify.
