12 years agoMAX3000 & Pwr On/Off Key
I want to use a MOSFET or may be bipolar transistor key to switch power supply ON/OFF for MAX3000 EPM3032 May such decision cause some problems? Clock frequency is not high - about 2MHz, and state of logic in power off mode is not disturbed. And what is better here - MOSFET or bipolar transistor? As I understand, EPM3032 consumes about 30mA when it doesn't work. I wouldn't like to add separate controlled voltage stabilizer for EPM30321 Reply
Using a MOSFET should be fine, you need to make sure you keep the MOSFET within its safe-operating-area during turn-on/off.
You could also consider using a USB power switch, such as the Texas Instruments TPS2051B. USB power switches have soft-start control, over-current output indicator, and they keep their internal MOSFET within its safe-operating-area. USB power switches are useful for power-sequencing without having to use separate linear regulators. Though I would recommend comparing the price on the MOSFET vs switch vs linear regulator. Cheers, Dave
