Gigiz
5 years agoMAX10M04 / Quartus Prime Lite Edition
Good morning, I'm completing a project with MAX10M04 FPGA and Quartus Prime 20.1 Lite Edition software. The project is in the final phase, everything works fine but I have a very strange problem: I...
Nurina
5 years agoHi Gigi,
Yes, I did. You can ignore most of them, but I suggest you do something about the multiple warnings about overlapping block or symbols. Follow the solution available here: https://www.intel.com/content/www/us/en/programmable/quartushelp/13.0/mergedProjects/msgs/msgs/egdfx_symbols_overlap_error.htm
Also, I've checked your pin planner and it seems that you are using a clock pin for the EXT_ENC4_ALARM node, I think that's the cause of the problem. Use a differential pin for this node like you did with the other ALARM nodes.
Nurina
Gigiz
5 years agoHi Nurina,
I have fixed all overlap blocks warnings ID 275059.
I have many warnings ID 332060 and one ID 332068 (no clocks defined in design),
how can I fix them ?
Gigi
