MAX10M04 / Quartus Prime Lite Edition
Hi Gigi,
Yes, I did. You can ignore most of them, but I suggest you do something about the multiple warnings about overlapping block or symbols. Follow the solution available here: https://www.intel.com/content/www/us/en/programmable/quartushelp/13.0/mergedProjects/msgs/msgs/egdfx_symbols_overlap_error.htm
Also, I've checked your pin planner and it seems that you are using a clock pin for the EXT_ENC4_ALARM node, I think that's the cause of the problem. Use a differential pin for this node like you did with the other ALARM nodes.
Nurina
- Gigiz5 years ago
Hi Nurina,
I have fixed all overlap blocks warnings ID 275059.
I have many warnings ID 332060 and one ID 332068 (no clocks defined in design),
how can I fix them ?
Gigi
- Gigiz5 years ago
Hi Nurina,
the hardware circuit is just connected to EXT_ENC4_ALARM and it is configured as standard input (I think).
I use other signals connected to others clock pin without problem.
The external clock is on pin 27.
I have also many warnings #332060, How I can configure the CLOCK input and associated it to the other signals ?
Gigi
