Mahmoud353's avatar
Mahmoud353
2 months ago
Max10M-16-SA-U-169 program without having the project file
Hi, I am trying to program the already designed and programmed Intel Max 10M-16-SA-U-169  to change the states of some of the components connecting to the FPGA. I do not have the project file and the pin assignment of the FPGA. I only have some .pof files that I can program the FPGA through the JTAG connection with a USB blaster. Is there any way to access the design of the FPGA through Quartus, or is there any way to do it with any other tools or software? Can I find out the pin assignment of the FPGA? I would appreciate it if anybody could help me with this situation.
  • FakhrulA_altera's avatar
    FakhrulA_altera
    Hi Mahmoud,
    Frank is correct, you can’t recover pin assignments from the bitstream, but with boundary-scan you can both observe and drive pin states by enabling outputs and setting values using tools like Quartus Programmer or TopJTAG. Just ensure you have the correct BSDL file and avoid driving against active outputs to prevent contention.
    Fakhrul
      FakhrulA_altera
      Hi  Mahmoud353,
      Thanks for your response. I will continue to monitor this post for the next 5 days. If there are no further inquiries during this period, I will step back and allow the community to assist with any future follow-up questions.
      Altera Technical Support
      FakhrulA_altera
      Hi Mahmoud,
      I wish to follow up with you on this case. Do you still have further inquiries on this issue? Please feel free to let me know if there is any concern so that we could further assist you.
      Fakhrul
        FakhrulA_altera
        Hi Mahmoud,
        Just checking in. Do you still have further inquiries on this issue? Please feel free to let me know if there is any concern so that we could further assist you.
        Fakhrul
  • FvM's avatar
    FvM
    Hi, boundary scan logic allows also to change data direction (enable/disable tri-state drivers) and set output state of pins. You can e.g. read or write memory devices connected to FPGA pins. There are various BSDL tools available,  I'm e.g. using TopJTAG Probe with USB-Blaster and Altera FPGA.
  • FvM's avatar
    FvM
    retrieving pin configuration and netlist from configuration bitstream isn't supported by vendor provided or commonly available tools. Scientific papers demonstrated however basic feasibility for unencrypted configuration files.
    Data direction and state of IO-pins of configured FPGA can be observed in operation with boundary scan tool.
    Frank
    • Mahmoud353's avatar
      Mahmoud353
      Thank you, Frank, for the response. With this method, only the state of the pins can be detected, so it cannot find the pin configuration. Another question is whether it is possible to change the state of the pins while they have been detected in this way?
