jjang's avatar
jjang
2 years ago
[MAX10] when Boot (CFM0) All IO port High → All port Low
as i know All FPGA have configuration Time.
During Configuration Time, All IO port weak pull up(100kΩ ~ 1MΩ) → All IO port High.
Can i change Pull-up → Pull-Down?
using Max10 Settings?
* My FPGA : 10M50SAE144i7
  • jjang's avatar
    jjang
    myself find.
    Device → Device and pin option... → [Catagory] Configuration → Device Options.. → Set I/O weak pull-ip prior usermode
  • Farabi's avatar
    Farabi
    Yes, you can set internal pulldown to the IO pins using the pin setting tool.
    regards,
    Farabi
    • jjang's avatar
      jjang
      it's mean. during Configuration => User Can modify each pin pull-up/down ?
      i tried both of them . doesn't not work. during configuration..
      My Device, 10M08SAE144C8G (3.3v Single Power Supply)
      set(Checked) Weak pull up Settings
      Pin planner → Reserved →
      > as output driving ground → High (when Configuration Time) , Normallay Low(when PWR UnStable) and Sometime High for Few ns
      > as output driving Vcc → High (when Configuration Time), Glitch_High(when PWR UnStable)
      unset(unChecked) Weak pull up Settings
      > as output driving ground → LOW (when Configuration Time), Normallay Low(when PWR UnStable) and Sometime High for Few ns
      > as output driving VccLOW (when Configuration Time), Glitch_High(when PWR UnStable)
  • NazrulNaim_Intel's avatar
    NazrulNaim_Intel
    As we do not receive any response from you on the previous question/reply/answer that we have provided, for now I will set this case to Close-Pending.
    Nazrul Naim
    NazrulNaim_Intel
    Nazrul Naim
    NazrulNaim_Intel
    Nazrul Naim
    NazrulNaim_Intel
    Nazrul Naim
    NazrulNaim_Intel
    Nazrul Naim
