[MAX10] when Boot (CFM0) All IO port High → All port Low
Yes, you can set internal pulldown to the IO pins using the pin setting tool.
regards,
Farabi
it's mean. during Configuration => User Can modify each pin pull-up/down ?
i tried both of them . doesn't not work. during configuration..
My Device, 10M08SAE144C8G (3.3v Single Power Supply)
set(Checked) Weak pull up Settings
Pin planner → Reserved →
> as output driving ground → High (when Configuration Time) , Normallay Low(when PWR UnStable) and Sometime High for Few ns
> as output driving Vcc → High (when Configuration Time), Glitch_High(when PWR UnStable)
unset(unChecked) Weak pull up Settings
> as output driving ground → LOW (when Configuration Time), Normallay Low(when PWR UnStable) and Sometime High for Few ns
> as output driving Vcc → LOW (when Configuration Time), Glitch_High(when PWR UnStable)
