MAX10 weak pull-ups and leakage current
I saw that, but its talking about +/-10uA. 160uA is a fair bit higher. It does say that the 10uA may be exceeded when using the clamp diodes. In fact that isn't what I see here. I see it happen not with the clamp diodes but the weak pull up on another pin that I'm not using.
May I know which version of Quartus are you using and if you can share you sample design.
- foft5 years ago
I've seen this in Quartus lite versions for the last few years, now using v20.1. I'll post the .qar this evening.
- AminT_Intel5 years ago
Is there any update from your end? I will close this case in 3 days from today if there is no update from you.
Thank you.
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
