MAX10 weak pull-ups and leakage current
This may happen because of leakage current in Max 10 device. There is a detail about tristated I/O pin on page 9 from this link: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_datasheet.pdf
I saw that, but its talking about +/-10uA. 160uA is a fair bit higher. It does say that the 10uA may be exceeded when using the clamp diodes. In fact that isn't what I see here. I see it happen not with the clamp diodes but the weak pull up on another pin that I'm not using.
- AminT_Intel5 years ago
May I know which version of Quartus are you using and if you can share you sample design.
- foft5 years ago
I've seen this in Quartus lite versions for the last few years, now using v20.1. I'll post the .qar this evening.
Is there any update from your end? I will close this case in 3 days from today if there is no update from you.
Thank you.
