foft
5 years agoMAX10 weak pull-ups and leakage current
I'm seeing significant impact from enabling weak pull-ups on pins other than the one I am using.
The specific case is as follows:
Device 10M02SCU169C8G.
In this design I have C1 and D1 connecte...
AminT_Intel
5 years agoHello,
This may happen because of leakage current in Max 10 device. There is a detail about tristated I/O pin on page 9 from this link: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_datasheet.pdf
- foft5 years ago
I saw that, but its talking about +/-10uA. 160uA is a fair bit higher. It does say that the 10uA may be exceeded when using the clamp diodes. In fact that isn't what I see here. I see it happen not with the clamp diodes but the weak pull up on another pin that I'm not using.
- AminT_Intel5 years ago
May I know which version of Quartus are you using and if you can share you sample design.
- foft5 years ago
I've seen this in Quartus lite versions for the last few years, now using v20.1. I'll post the .qar this evening.
