fra29
5 years agoMax10 vccio power sequence
I want to use a Max10 FPGA (10M04DAF256) with two different VccIO voltages: 3.3V and 1.8V.
The issue is that the 3.3V and 1.8V power supplies will not ramp at the same time.
Banks 1B and 8 ...
- 5 years ago
Yes that will be okay.
AminT_Intel
5 years agoHello,
Yes they will enter the user mode if that is how you designed it. You can refer to page 28 of this document for detailed explanation of configuration sequence for Intel Max 10 devices from this link: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf
Thank you,
Amin
fra29
5 years agoHello Amin,
Thank you for your answer concerning the user mode.
Is it safe for the device to have some of its IO banks powered seconds after VCC, VCCINT, VCCA, VCCD_PLL, VCCIO8, VCCIO1B ?
Best regards
- AminT_Intel5 years ago
