9 years agoMAX10 UFM writing takes much longer than expected
Hi Folks, in my design on a MAX10 10m08sau169 I am using the internal user flash UFM to store some data. I am NOT using a NIOS to do the writing through the avalon interface. Instead of this I ...
8 years agoI suggest you look at the following link
https://www.pulserain.com/m10-high-speed-config It is an open source solution for config the MAX10 in high speed. It might have what you need. In particular, look at the TRM https://github.com/pulserain/m10_high_speed_config_rtl/raw/master/docs/m10_high_speed_config_trm.pdf
