EP1
3 years agoMAX10 UART RSU - RemoteTerminal.exe DOES NOT WORK
Hello, I have been reading the posts and I'm in a similar situation to the following post: MAX10 UART RSU EXAMPLE NOT WORKING - Intel Community There is no way I can see any information on the Rem...
EP1
3 years agoThe steps followed are:
1. Program the FPGA with pfl.sof (successfully)
2. Program the Nios II firmware into QSPI Flash (this is NOT successful).
As a conclusion, the QSPI Flash doesn't get programmed and the RemoteTerminal does not execute the code from remote_update.c
Can anybody provide a correct nios_firmware.pof?
Also, the file softwarearchive.zip is missing from the RSU project. It is needed to manually create nios_firmware.pof
EP1
3 years agoPicture from the previous fail when programming QSPI Flash
