10 years agoMAX10 TSD problem (CH 17 ADC)
Hi, I am working on temperature sensing diode(TSD of MAX10 SAU169C8GES). I am getting value 57 (decimal) on the channel number 17 always. f = 10 MHz external VRef = 2.5V Mode = Standard ...
10 years agogreat, perhaps value sequencer_csr_writedata <= X"1" for sequencer good enough to run continous
But you should consider calibration cycle when changing from temprature to normal sampling... but I advise to recheck sequencer, for disabling channels from 9 to 16 for U169 defice. in the sequencer you can put TSD channel is slot only once(twice, thrice) in the middle of sequence and fill others slots for your signals, i suggest your use all 64 slots available.
