10 years agoMAX10 TSD problem (CH 17 ADC)
Hi, I am working on temperature sensing diode(TSD of MAX10 SAU169C8GES). I am getting value 57 (decimal) on the channel number 17 always. f = 10 MHz external VRef = 2.5V Mode = Standard ...
10 years agookay...
you can turn off all channels except TSD to check functionality. You can open pin planner for you device and check bank 1A - 8 pins. Then you need to check ADC IP parameters that not more than 10 channels = 1dedicated analog + 8 dual function + 1tsd
