dabo
4 years agoMAX10 start-up problem
We are using a MAX 10 (10M04SCU169A7G) on a custom board and are experiencing start-up problems on 2 out of 40 boards. The MAX 10 is programmed by an MCU on the same board using the embedded...
YuanLi_S_Intel
4 years agoSince 2/40 boards are having issue and all of them are having the similar setup. Chances that the issue is due to device or the trace/termination on the board.
Can you do swapping on the faulty board with known good device? Also, if the recommended pin connection guidelines on the MAX10 is not fulfilling, it could cause trouble also in programming/configuration.
