takur's avatar
takur
4 years ago
MAX10 RSU
I have implemented RSU over i2c based on this example:
https://www.intel.com/content/www/us/en/design-example/714746/max-10-i2c-remote-system-update-example.html
It’s been working good with a MAX 10M8SAE. I now changed to a MAX 10M16SAE, and regenerated the IP cores for this model.
Configuration mode:
- configuration mode: Dual compressed Images
Flash memory:
- sector 1 - 0x00000 – 0x03fff - UFM
- sector 2 - 0x04000 – 0x07fff - UFM
- sector 3 - 0x08000 – 0x2dfff - CFM (Image 2)
- sector 4 - 0x2e000 – 0x49fff - CFM (Image 2)
- NA – NA – CFM (Image1)
I understand that when using Dual compressed Images, sector 2 and 3 are merged leading to a generated rpd image size of 270336 bytes (0x42000) and that the RSU flash offsets by multiple of 4 bytes. So for 0x08000 - 0x49fff range, RSU indexing goes from 0x2000 – 0x127ff.
Yet I get a “flash error” from bit 4 of PrimaryErrors (reg 0x81) when writing passed flash offset 0x0dfd4 (57300).
What am I missing?
  • We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
  • Hi Tapani,
    Apologize for the delay in response.
    When you change from MAX 10M8SAE to MAX 10M8SAE, is there any other changes that were made for the setting or during configuration?
    Aiman
    • takur's avatar
      takur
      Hi
      No any other changes. Design works fine, but RSU doesn't work.
  • Hi,
    Please provide the full error message/screenshot. Including the error code.
    Aiman
    • takur's avatar
      takur
      Hi
      How I can get error code from this example? Is there any others error registers?
      Now I can read from register 0x81. This indicate FlashError (bit2 is 1).
      `define ADDR_PrimaryErrSts 129 //8'h81
      RegFile[`ADDR_PrimaryErrSts][ 2] <= FlashError;
      Tapani
