rt52
3 years agoMAX10 RSU with encrypted .pof
I have a design that relies on RSU for remote updates. I currently encrypt the .pof file for JTAG programming. When generating that encrypted .pof file, I also choose to generate the .rpd files tha...
FakhrulA_altera
3 years agoHi rt52,
Sorry for the delay in response. From your flow, nothing sounds out of the ordinary to me.
- May I know if this is a singular case or are you seeing the same issue in other new devices?
- Can you consistently replicate this issue?
- Can you try to perform a full chip erase and see if the issue still persists?
Please let me know if this works for you. Thank you.
Fakhrul
rt52
3 years ago1. This issue follows other boards, although they are all the same board design.
2. Yes this issue will always happen. Downloading the .rpd will work and boot into the application image every time without encryption but will not work when trying with encryption.
3. Full chip erase does not help the issue
