MAX10 RSU with encrypted .pof
Hi rt52,
I'm not sure you have taken a look the following steps on generating .ekp File and Encrypt Configuration File in the User Guide on page 41 as I'm assuming there could be some problems on the file generation.
Fakhrul
Hello, this is the .cof file I am using to generate the encrypted .pof and .rpd. I have a script that replaces the generic values with the inputs to the script that are the respective .sof, . ekp and .key file. The generated .pof is labeled as "encrypted" and the CFM 1 .rpd file is used and the other 2 are removed because I do not use those. This .cof is identical to how the unencrypted one works except for the .key/.ekp fields which are excluded. The same process is used to give me the final .rpd and .pof but the unencrypted version works perfectly and the encrypted one does not.
