rt52
3 years agoMAX10 RSU with encrypted .pof
I have a design that relies on RSU for remote updates. I currently encrypt the .pof file for JTAG programming. When generating that encrypted .pof file, I also choose to generate the .rpd files tha...
Farabi_Altera
3 years agoHello,
if referring to : https://www.intel.com/content/www/us/en/docs/programmable/683762/21-4/generating-the-initial-rsu-image.html
"For security application when you need to generate a signed or encrypted .rbf file, you need to first generate .rbf file from a .sof file, and only then generate the initial RSU image from the .rbf file."
Is it possible to follow above instruction for security application?
regards,
Farabi
rt52
3 years agoThis does not work. Please advice. Is there a way, on a MAX10, to perform a remote update with encryption enabled?
