MAX10 RSU with encrypted .pof
if referring to : https://www.intel.com/content/www/us/en/docs/programmable/683762/21-4/generating-the-initial-rsu-image.html
"For security application when you need to generate a signed or encrypted .rbf file, you need to first generate .rbf file from a .sof file, and only then generate the initial RSU image from the .rbf file."
Is it possible to follow above instruction for security application?
regards,
Farabi
- rt523 years ago
This does not work. Please advice. Is there a way, on a MAX10, to perform a remote update with encryption enabled?
- rt523 years ago
That document refers to a Stratix10, I am using a Max10. I can try the equivalent on Max10.
The process for generating the encrypted files is as follows:
1. Compile design, .sof is created
2. Take .sof into Convert Programming Files
3. Using .key file, generate encrypted .pof and encrypted .rpd and .ekp file from the base .sof
4. JTAG program the encrypted .pof with the .ekp
What you're telling me to do is add a step in step 3 where I would generate a .rbf file from the .sof, then encrypt that .rbf to make an .rpd file that is encrypted that can be downloaded into flash?
