9 years agoMAX10 Remote System Upgrade- Program Error
Hi ,
I'm trying to develop a RTL state machine in VerilogHDL for remote system upgrade using I2C interface, in a MAX10 (10M16324C8G) device. I have instantiated 'onchip flash memory IP core' in the code for the same. The configuration mode in the onchip-flash IP is set as 'Dual Compressed images' and clock frequency to be 33MHz. After un-protecting and erasing the sectors (CFM1 and CFM2) , while programming single page at a time starting from the location 0x08000 (a page size is 4KB for 10M16324C8G) , it works well till the address location 0x13000 . I confirmed it by reading the 'write successful' bit of status register. But the write/program fails from location 0x14000 on wards. I'm providing the address in 'avmm_data_address' pin, data in 'avmm_data_writedata' with the 'avmm_data_write' to be high until the flash IP core goes busy. The 'burst_count' is set to '1'. I found that the 'avmm_data_waitrequest' goes low in the 3rd clock pulse after 'avmm_data_write' control pin is set for this address. Please help me what could be the reason of failure from address location 0x14000 page on wards Thanks in advanceNo RepliesBe the first to reply
