10 years agoMAX10 remote configuration with MCU
Design objective is to allow remote configuration update over ethernet with MCU. Is there a reference design or recommended method for this type of configuration?
10 years agoAlex - thanks for post, -reviewed the reference info you mentioned. Was hoping there was a possible option using external spi flash, where the spi flash would sit between the mcu and the fpga. This would allow the mcu to load spi flash, and then signal the fpga to load from the spi flash. This is kind of a common method with some other devices which are designed to load from external spi.
Thanks -Bob
