GSica
6 years agoMax10 propagation delay and frequency error
In a Max10 10M02SCE144I7G I have a variable frequency input signal from 0Hz to about 80kHz. On that signal I apply a digital filter to remove the glitches (without changing the frequency with a gloa...
AnandRaj_S_Intel
6 years agoHi,
If you have connected the input to output without any logical operations, You have to see the same signal with the same frequency.
- How are you are comparing the signals using Oscilloscope and probing on hardware right?
- Which pin in hardware are you checking/probing?
If you are seeing different signals.
- You are checking at the wrong place on the hardware/PCB board.
- The output of FPGA is passing through passive or active components.
Anand
