GSica
6 years agoMax10 propagation delay and frequency error
In a Max10 10M02SCE144I7G I have a variable frequency input signal from 0Hz to about 80kHz. On that signal I apply a digital filter to remove the glitches (without changing the frequency with a gloa...
GSica
6 years agoHi
4 pins because the signals to be filtered are two different, but my tests are aimed at only one channel, the other is off. Also the other MAX10 functions are off.
Giovanni
