GSica
6 years agoMax10 propagation delay and frequency error
In a Max10 10M02SCE144I7G I have a variable frequency input signal from 0Hz to about 80kHz. On that signal I apply a digital filter to remove the glitches (without changing the frequency with a gloa...
GSica
6 years agoI checked the assignment, but in my projects all the I/O pins have a specific function, these 4 pins perform the filter of a frequency signal and the output signal is incorrect, but analyzing it with the oscilloscope what appears is rather a distortion due to the delay on the fronts that deceives the frequency meter.
What kind of assignments you refer to? Phisical pins, specific property?
Giovanni
