GSica
6 years agoMax10 propagation delay and frequency error
In a Max10 10M02SCE144I7G I have a variable frequency input signal from 0Hz to about 80kHz. On that signal I apply a digital filter to remove the glitches (without changing the frequency with a gloa...
AnandRaj_S_Intel
6 years agoHi,
You have to probe exactly the Output of FPGA,
If you probe the signal after it passes through an active or passive component you will see the difference.
Also check the pin assignments.
Anand
