GSica
6 years agoMax10 propagation delay and frequency error
In a Max10 10M02SCE144I7G I have a variable frequency input signal from 0Hz to about 80kHz. On that signal I apply a digital filter to remove the glitches (without changing the frequency with a gloa...
GLees
Contributor
6 years agoYou need to listen to Anand and check your pin assignments first. You've got something fundamentally wrong that has nothing to do with schmitt triggers or current drive. Also, is your digital scope aliasing and giving you a false reading?
