GSica
6 years agoMax10 propagation delay and frequency error
In a Max10 10M02SCE144I7G I have a variable frequency input signal from 0Hz to about 80kHz. On that signal I apply a digital filter to remove the glitches (without changing the frequency with a gloa...
GSica
6 years agoExactly yes by connecting the input to the output I am not getting the expected output.
I got a slight improvement by removing the "schmitt trigger" setting from the input pin.
Today I have been busy with other things, but tomorrow I will try to set the maximum current to the output pin, at the moment it is set to 3.3V LVTTL with minimum current.
Giovanni
