9 years agoMAX10 Programming .pof is not working
I have a problem with internal flash programing on my custom board with MAX10 10M25SAE144I7G. In the Configuration options I use Internal Flash, Single Uncompressed Image (1920Kbits UFM). In Pow...
9 years agoWe have found a workaround. It was hardware issue. One of these pins was connected to the external button with hold up. I don't remember which pin it was, i can check in the next week. When We tested our hardware without external button everything was working. The default state on this pin was High. When we added external button it was working randomly because when the button was upholded it forced Low state on the pin and caused power up problem. In the next our hardware revision we try no to use config pins as IO.
