Jacob11's avatar
Jacob11
4 years ago
Max10 programming external flash
Hello guys. I am trying to figure out how to write to an external flash. Micron mt25QL02 is what is on the board. I don't want to use Nios, or the flash memory programming tool. I am trying to use...
  • Jacob11's avatar
    4 years ago
    After much trial and error, I have it working. Now I can write to and read from/erase the memory. Basically, I found and error in the Intel example design. Once I corrected it, everything works.
    For anyone else who might try it using Nios.
    First you have to do a write enable like this:
    IOWR(EXT_FLASH_AVL_CSR_BASE,0x7,0x00000006);
    IOWR(EXT_FLASH_AVL_CSR_BASE,0x8,0x1);
    then you can write 0xabcd1234 into the memory like this(this is where the example design had mistakes):
    IOWR(EXT_FLASH_AVL_MEM_BASE,0x00000000,0xabcd1234);
    Then to read it back, do it like this:
    IOWR(EXT_FLASH_AVL_CSR_BASE,0x4,0x00000000);
    IOWR(EXT_FLASH_AVL_CSR_BASE,0x0,0x00000101);
    IOWR(EXT_FLASH_AVL_CSR_BASE,0x5,0x00000003);
    return IORD(EXT_FLASH_AVL_MEM_BASE,0x00000000);
    The most confusing parts are these offsets 0x4, 0x5....etc. I have figured out what most of them are, so I will list them below:
    0x0 control register
    0x4 operating protocols
    0x5 read instructions
    0x6 write instructions
    0x7 flash command setting
    0x8 flash command control(basically always write 0x1 here when writing into the status registers to begin the operation)
    0x9 flash command address register
    0xA flash command write data
    0xC flash command read data
    Why this isnt included in any documentation I have no idea. Basically, once I understood what these offsets were doing I had it up and running in just a few minutes. Hopefully these short notes help the next person.
