YDu00's avatar
YDu00
6 years ago
MAX10 programming and verification very slow
I am using Max10 FPGA. programm SOF file is fast. programm POF file is a little slower, but acceptible. However, after programming POF, it takes 20 minites for the programm verification process. Is this reasonable?
  • YuanLi_S_Intel's avatar
    YuanLi_S_Intel
    Hi Yongjiu,
    Sorry for late as i was checking with internal team. Yes, it can be and depending on the size of the bitstream as well.
    Thank You.
  • YDu00's avatar
    YDu00
    Thanks. But is it normal to take 30 Minutes?
    YuanLi_S_Intel
    Hi Yong Jiu,
    Yes, programming itself is fast. But when the other option is enabled in Quartus such as verification and examine, the time is longer.
    Thank You.
  • YDu00's avatar
    YDu00
    Please see the following system info.
    "Info (209023): Programming device(s)" this step takes 1 minute.
    BUT, "Info (209021): Performing verification on device(s)" ,this step takes 20 minutes.
    YuanLi_S_Intel
    Hi Yong Jiu,
    Programming of SOF is faster than POF and this is legit. The reason is because SOF is volatile and POF is non-volatile.
    You mentioned about 20 min program verification, what is that? Is that a time in programming a MAX10 or boot up a MAX10?
    Thank You
