9 years agoMAX10 power-on/configuration error
I have a custom board with a 10M25SAE144xxx part that I am trying to bring up, but the device seems to be failing configuration at power-on. This is a single-supply device, and power is applied thro...
9 years agoThanks Plewis and FvM.
Yes, it looks like my problem is a bit different. I can download the SOF file through JTAG and it works fine. But when I created a POF and booted it from flash, it doesn't work. nSTATUS has a voltage of 2.4V with a 10K pull up resistor. I have a 10K pull up resistor on CONF_DONE also and the voltage on CONF_DONE is 3.2V. I don't have the dual boot image option turned on, just a single compressed image. Glad your problem was fixed by replacing it with a new part.
