9 years agoMAX10 power-on/configuration error
I have a custom board with a 10M25SAE144xxx part that I am trying to bring up, but the device seems to be failing configuration at power-on. This is a single-supply device, and power is applied thro...
9 years agoI mistakenly started 2 threads on this topic. This will take you to the other one that has more discussion...
https://alteraforum.com/forum/showthread.php?t=56018 However, your problem does sound different from mine. I was not able to get the initial JTAG connection. I ended up replacing the part on my board and it has been working fine ever since.
