9 years agoMAX10 power-on/configuration error
I have a custom board with a 10M25SAE144xxx part that I am trying to bring up, but the device seems to be failing configuration at power-on. This is a single-supply device, and power is applied thro...
9 years agoHi, have you found a solution for the configuration issue? I have the same 10M25SAE144 part and the same problem. It doesn't boot up from internal flash. JTAG download is fine.
