Nirrr's avatar
Nirrr
1 year ago
Max10 nstatus pin without pull-up
I have boards without a pull-up for the nstatus pin, some of which work well and others do not.
What can I do to complete the configuration process without adding a pull-up?
  • FakhrulA_altera's avatar
    FakhrulA_altera
    Hi Nirrr,
    As we haven't received a response to our previous notification, this thread will be transitioned to community support. We hope all your concerns have been addressed. If you have any new questions, please feel free to open a new thread to receive support from Intel experts. Otherwise, community users will continue to assist you here. Thank you.
    FakhrulA_altera
    Hi Nirrr,
    As sstrell mentioned, there’s no reliable workaround without the pull-up on the nSTATUS pin. A board rework or respin would be the recommended path forward.
    Do let us know if you have any further questions, otherwise, we’ll mark this thread as inactive and transition it to community support.
    Fakhrul
    FakhrulA_altera
    The MAX 10 needs a pull-up on the nSTATUS pin to work reliably during configuration. Without it, the pin can float and cause random issues — that’s why some boards work and some don’t. I’d suggest adding a 10kΩ pull-up to VCCIO to fix this. Let me know if you have any questions.
    Fakhrul
    • Nirrr's avatar
      Nirrr
      Thanks!
      But, I can't add a pull up on this pin.
      I need another solution.
      • sstrell's avatar
        sstrell
        I think it's pretty clear there is no work around for this. Time for board rework or a respin.
    • Nirrr's avatar
      Nirrr
      So how come most boards work well without a pull up? Is it random?
      Thanks!
      • sstrell's avatar
        sstrell
        "Most boards" is not all boards. If this is a board you are putting into production, you would not be able to go without the pull-up.
        Why is it working on these boards? Not sure. The die on the ones that are working may be able to barely get to the high voltage level needed to register correctly. Luck of the draw (and luck of the fabrication).
