MDISC
6 years agoMAX10 JTAGEN connections
Hi, if I enable the JTAG pin sharing for a MAX10 device, can I drive the JTAGEN pin directly by a microntroller to switch the JTAG pins from jtag function to user I/Os? Is there any problem if I con...
Rahul_S_Intel1
6 years agoHi ,
That will be great, one more suggestion , if you have doubt on any pin connections, Kindly refer to the pin connection guidelines that will give you the information about all pins connections , with the above may I close the case .
I
