MDISC
6 years agoMAX10 JTAGEN connections
Hi, if I enable the JTAG pin sharing for a MAX10 device, can I drive the JTAGEN pin directly by a microntroller to switch the JTAG pins from jtag function to user I/Os? Is there any problem if I con...
LBeau2
6 years agoNo it must be tried to VCC with a pullup of 10k
Avoid using this pin if you have other pins available.
But it can be used as a regular IO.
