9 years agoMAX10: JTAG sharing not working -- how to erase fw-image?
Hi, target MAX10: 10M02SCU169 Quartus: 15.1 I was trying to use JTAG sharing on MAX10 so I checked "enable JTAG sharing" and unchecked "enable nCONFIG, nSTATUS, CONF_DONE" and generated ...
9 years ago --- Quote Start --- Hi, target MAX10: 10M02SCU169 Quartus: 15.1 I was trying to use JTAG sharing on MAX10 so I checked "enable JTAG sharing" and unchecked "enable nCONFIG, nSTATUS, CONF_DONE" and generated JTAG-sharing-fw1 putting JTAG pins to hi-z in user mode. The JTAGEN is pulled-up always (so JTAG-port should always be active) I succeed to upload JTAG-sharing-fw1 to MAX10 but immediately after I don't get access to JTAG-port anymore: JTAG-Autodetect command from Programmer-windows is not working anymore and MAX10 device is not recognized "unknown device". I repeated this test with 3 more boards, all fails the same: they work correctly with any firmware where JTAG sharing is disabled. I suspect that JTAG-sharing-fw1 is preventing the JTAG-port to work correctly and that for some reasons, JTAGEN is perhaps not correctly sampled (I didnt try to toggle the JTAGEN to see if anything happens) My questions: 1st q: i want to erase the jtag-sharing-fw1 image from max10 and get back an "empty" MAX10 Could you please tell me which is the procedure? As far as I could understand, after poweron, I have to set nCONFIG to low and hold it. This will set MAX10 in reset mode so preventing JTAG-sharing-fw1 to be loaded. While nCONFIG is hold low (FPGA in RESET state) will JTAG-Autodetect command work? Should I drive nSTATUS and CONF-DONE as well? how? L --- Quote End --- Hi, got some info reporting this bug on Quartus from here: " Why can’t I access the MAX 10 device via JTAG even though JTAGEN is pulled high in user mode?" https://www.altera.com/support/support-resources/knowledge-base/solutions/rd03222016_95.html and here: "How do I gain access to the JTAG pins of my MAX 10 device if I have enabled the JTAG pin sharing option, and the Quartus Prime Programmer is unable to auto detect the device?" https://www.altera.com/support/support-resources/knowledge-base/solutions/rd05192016_963.html In my design, nCONFIG-nSTATUS-CONF_DONE are connected to CPU-GPIOS; so after poweron, I tried to assert-low nCONFIG and hold it low and tried to access JTAG-port with Quartus programmer Autodetect; it doesnt work. Same if I assert-low all signals nCONFIG-nSTATUS-CONF_DONE My question is: To erase fw we must force a fw-reload which is triggered by following events (ref to m10_handbook.pdf at page 477) "........ Reconfiguration is triggered by the following actions: • Driving the nSTATUS low externally. • Driving the nCONFIG low externally. • Driving RU_nCONFIG low." since in the JTAG-sharing-fw1 generation I have enabled JTAG-sharing and DISABLED nCONFIG-nSTATUS-CONF_DONE, such pins wont work anymore so it is normal that this procedure must fail. Since nCONFIG is disabled, how to get control back on the JTAG-port? BR, L
